ArchiCAD Crashes every time I quit
kevin b
Anyone have this issue, or know how to fix it? Whenever I quit ArchiCAD it crashes, I get Bug Reporter, I send it in. Does not matter whether its a solo or TW file, or which version 20, 21 or 22. Does not seem to lose any data. I do not get the file was open on crash thing the next time I start up. So it is an annoyance, more than anything. But it has been going on for quite some time and it is very annoying at the end of the day if I have multiple instances open, and have to shut them all down.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
5 REPLIES 5
You had to try these :
- Update your Archicad
- Delete all the plist files into the Finder/library/Preferences
- Restart Archicad
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
Daniel Kovacs
If your ARCHICAD is still crashing, if you send me the Bug ID you get when you send in the crash report, I can take a look at the system, to see if this is a common issue (hopefully with a simple solution).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
fuzzytnth3
I had this issue after I installed the Solibri SMC link plug-in. Unistalled the plug-in and it stopped crashing
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
kevin b
@ fuzzytnth3 that was totally it!!! I removed the SMC add-on and no more crashing. I have had this issue for over a year and sent every crash report to GS with nothing. You have saved the day.
kevin s burns, AIA
massachusetts, usa
Windows 10
fuzzytnth3
Glad to have helped
