ArchiCad forgets paper settings
Each time I want to print my layouts (A3 landscape), ArchiCad uses A4 portrait instead, wasting tons of paper that way.
So each time we're going to print we have to manually readjust the paper settings. Is this a known bug?
5 Replies 5
I don't think so.
You will probably find it is your printer defaults set to A4.
Change those and all shoud be fine so long as you always want to print on A3.
Better still duplicate your printer and call it A3 and set the defaults correctly.
Now from Archicad (or any other application) you just have to choose to print to the correct printer.
Hmm, that might be a windows solution. On a Mac, it always kept the print settings individually for each publishing set.
__archiben
there is something odd about the way the publisher and the print dialogue is handled on a mac. the print dialogue box works independently to the saved print settings in the publisher: therefore when you open up the print dialogue from within an already established publishing set you get to see the default[/] print dialogue and NOT the saved print settings.
this is Bad and extremely frustrating. i'm guessing GS will claim it a 'system limitation' but that doesn't help any.
i'm sure there is also some bug in there that blitzes previous settings sometimes. i could swear blind that i set up publishing sets one way and find that they do something completely different when it comes time to use them. i just can't put my finger on what is going on.
on a related - and side - note. i notice that in leopard some apple applications are now (finally) able to handle the 'page setup' stuff directly out of the 'print' dialogue. i'm hoping that this is going to become the norm and will provide a far more efficient printing framework that other applications can use.
~/archiben
b e n _ f r o s t
Stress Co_
INDEED. Baffling that Print and Page Setup are not combined for every application (I've only noticed it in Safari, Mail and iPhoto).
Marc Corney, Architect
Red Canoe Architecture, P. A.
__archiben
and Preview & iCal . . . although i think iCal has had that kind of functionality in for quite some time.
~/b
b e n _ f r o s t
