‎2005-10-25 09:10 PM
‎2005-10-26 09:26 AM
‎2005-10-26 07:28 PM
Fabrizio wrote:
If you want to use the plug-in with more than one dongle you should buy one Registration ID for each ArchiCAD dongle...
‎2005-10-27 01:22 AM
‎2005-10-27 01:28 AM
Fabrizio wrote:And therein lies the problem. I would also think that it SHOULD work this way, but when I tried that, I could never get it to accept the proper code (I even tried putting in the codes for the other key, just to check - same response: didn't work). I don't know if I should try re-seri_al_izing since I have all the codes I need, but it's not working by just typing in the proper codes.
...You simply have to serialize the add-on with the proper unlock code...
‎2005-10-27 08:53 AM
