Archicad 15 pln file Crashes on Loading module: Attributes
I was working on my architectural working drawing details. While i was saving the project (saving was not completed) electricity has gone i turned on my pc after electricity come and tried to open my .pln file it crashes and wants to send bug report, the crash happens while project is being loaded it loads the library after that it comes to attributes and it crashes archicad closes. I've tried merging in new file it failed. I tried to open bpn version of file but it fails again on module: source reference manager and says '' warning! Error while loading plan file! Module: Source Reference Manager.'' I click on ignore error and continue it says '' Integrity Checking Error Project data was damaged in the last step. i again click continue there is nothing on page just like i've opened a new file...
these are the errors in pictures
Please help me this is very very important for me i've sent a bug report but there's no reply
1 Reply 1
I would guess that your disk/registry/etc got corrupted when you had the power failure.
Run a full chkdisk (reboot required), run any maintenance software you have (e.g., to clean up temp files, etc) and reinstall ArchiCAD.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
