2023-04-10 09:00 AM
Hi, I am looking to a link to Archicad 25 AUS for Mac to test it out if possible ?
Solved! Go to Solution.
2023-04-11 05:42 AM - edited 2023-04-11 05:42 AM
@mthd wrote:
I found that one yesterday but I couldn’t get directly to AC25 AUS for Mac ?
Just adjust the settings to any language, program, version or platform you want.
AUS Mac 25 is there.
2023-04-10 10:11 AM
You’ll only be able to get a copy of Archicad 26 for evaluation purposes. There is a free trial available.
2023-04-10 12:36 PM
Thanks Lee, I did download a Windows version of AC25 for evaluation a few months ago but that PC is over 13 years old now. I takes quite a while to fire up. I am seriously considering upgrading to 26 before the end of May. I want to see how good Redshift is at Rendering but I think I will need 26 anyway to test that out. From what I read Redshift was only a technology preview in AC25 and only available for GS forward clients as I understand.
2023-04-10 03:18 PM
That’s right. I think Redshift is still only available for Forward customers but if you get a license of AC26 now I believe it will come with a year of Forward and access to those features.
2023-04-10 04:31 PM - edited 2023-04-10 04:33 PM
@mthd If Redshift is a key feature for you then check the technical requirements. I bought a high spec Mac in 2019 not long before Redshift was added and it wouldn't work with it. It required an advanced graphics card at the time.
https://graphisoft.com/forward/redshift-for-archicad
2023-04-11 03:19 AM
All versions of Archicad back to 18 for all operating systems can be downloaded from the Graphisoft website.
If you don't have a valid license, they will run in demo mode only.
2023-04-11 05:21 AM - edited 2023-04-11 05:31 AM
I hope my Apple M1 Max can handle it with it being rated at 7.8TF and equivalent to an 8GB video card apparently ?
https://appleinsider.com/articles/21/10/19/m1-pro-and-m1-max-gpu-performance-versus-NVIDIA-and-amd
The system requirements seem to indicate that it will work but that’s why I have to test it out first for low rise residential work.
https://graphisoft.com/resources-and-support/system-requirements
2023-04-11 05:23 AM - edited 2023-04-11 05:35 AM
Cheers Barry, thanks for the link.
I did however get your link for AC25 AUS windows a few months ago but my windows machine only has a 2MB video card in it. Not able to handle Redshift.
2023-04-11 06:15 AM - edited 2023-04-12 04:57 AM
My Apple iPad mini 2 is to blame because it’s IOS is still at 12 something. A 2013 model and so it needs upgrading but they will not let it go above IOS 12 at present.
Found it on my Mac.
Thanks again.
Edit: Redshift current limitations for AC25 & AC26
Are all these limitations still applicable in AC26 ?
