2023-12-22 10:24 AM
I'm facing the following issue, but I don't know if it is specific to my machine: I made the curious conclusion, that Archicad 27 being open causes Archicad 26 instances to crash instantly when being switched to.
It doesn't matter whether it is a teamwork or single file, if I open AC27 and switch back to any of my AC26 projects, the active AC26 instance instantly dies.
Steps to reproduce:
1. Have any AC26 file open
2. Open any AC27 file
3. Have the AC26 window active again
4. Enjoy
Anyone else experiencing this? This is really annoying, as I often have older/other currently running projects which I would like to reference, and this issue makes this impossible.
SW: macOS Ventura 13.5.2 (22G91) with AC27 INT b4001 and AC26 INT b5003
HW: M1 Max MBP (64 GB + 24c)
2024-01-19 04:17 AM
Currently having a similar issue. Archicad 26 will open but crashes eventually even if AC27 isn't running. The install of AC27 must be interfering with AC26 running somehow.
I'm still using 26 until I upgrade CI Tools but noticed this was happening after installing AC27.
Generally once I have the latest Archicad installed I delete the previous versions altogether.
If your libraries are replicated correctly you shouldn't need to open older jobs in AC26.......?
2024-01-19 01:24 PM
Hi, Since I've updated AC27 to build 4030, I'm getting this problem infrequently.
Which build are you on? I've also toyed with the idea of updating the OS to Sonoma, but I don't know what can of worms that would open, so I haven't done it.
Yes, you can migrate all your projects to 27 - in my case this is not an option for all jobs.
2024-02-13 12:00 PM - edited 2024-02-13 12:01 PM
It's been a while since I noticed this happening, but today I got a crash again:
- Opening an AC27 (4060 INT) file (.pln) made AC26 (5003 INT) crash (Teamwork file)
Bug report ID: AC26-2024-02-13-06-10-49-6929
2024-02-13 01:31 PM
I think there is a newer update to Archicad 26 that prevents this from happening? AC26 is on build 6XXX.
2024-02-13 05:54 PM
Teamwork project, close to a deadline – I cannot update atm.
2024-02-27 06:45 AM
Completed the AC26 update.
No more crashing.
