4 weeks ago
Archicad 28 is constantly freezing or crashing, diving a Direct3D / graphics card error.
Archicad 27 and Archicad 26 do not have the same problem.
I've updated graphics drivers, and uninstalled / reinstalled Archicad to no avail.
I get the same error every time; sometimes, it's within seconds of opening the program. Other times, it can take several minutes. But it happens multiple times a day.
'Direct3D Runtime received a Device Removed Message DXGI_ERROR_DEVICE_HUNG'
That's typically an issue with either the graphics card itself or the graphics card's connection the rest of the machine. However, this is the *only* program experiencing the problem, which is usually indicative of a glitch in the program or an incompatibility between the program and the graphics drivers.
These are two of the smallest projects I've ever done in Archicad, and the only two on 28 so far. Archicad 28 appears to be sending conflicting instructions to the GPU, which causes it to hang. No other programs are effected when it happens; in some instances, when it happens in one Archicad 28 file, it doesn't even impact the *other* Archicad 28 file I've got open.
Dell XPS 15 9530 with NVIDIA GeForce RTX 4060 Laptop GPU.
Archicad 28.0.2 (3110)
2 weeks ago
I have the exact same issue. Direct3D Runtime received a Device Removed Message DXGI_ERROR_DEVICE_HUNG. Happens once or twice a day.
No issues with 26 or 27. 3D view is generally good but does certainly lag when trying to edit objects with nodes in 3D in 28.
RTX4070ti super
64gb ram
i7 14700F
2 weeks ago
Disabling background rebuild / model update all but eliminated it. Combined with a drivers update from NVIDIA, it *appears* to no longer be an issue for me, but I'm not going to risk it.
Tuesday
We have the same problem.
Latest NVIDIA Studio Driver 572.16 on RTX 3060 GPUs.
One user with a Surface Laptop Studio GeForce RTX 3050 Ti.
Happens maybe twice a week.
Seems like it does not matter which user or which project.
Maybe this is a coincidence, but it does not happen for our Intel Iris users, so maybe the issue is with NVIDIA?
NVIDIA is the only common denominator.
