Rolla1702
Archicad 28 laggy and slow to response with updated macOS Tahoe
Hi
Archicad 28 is experiencing significant performance issues on macOS Tahoe (on M1 Apple silicon iMac) with constant lags and very slow response times. The software worked without any issues on the previous macOS version.
Could you please inform us about when we can expect an update or fix to address this compatibility issue?
Thank you
Operating system used: Mac Apple Silicon Tahoe
15 Replies 15
@Rolla1702 is there any chance that you accidentally installed the Intel version of 28 on your Apple Silicon Mac?
Anna 13
Yes, that's right! I have Archicad 28 and macos Sequoia 15.7.2 installed, but the Cineware Maxon visualization does not work, I want to try updating macos to Tahoe, I'm worried if the Cineware Maxon visualization will work? If she works for you, she should work for me too. I make visualizations directly in Archicad.
I know nothing about MAC OS, but maybe this will help.
https://community.graphisoft.com/t5/Visualization/Cineware-renderer-quits-in-ArchiCAD-28/m-p/635438#...
Anna 13
It helped, thanks!
ryejuan
I also encountered this especially if I have several archicad versions opened eg. 27,28,29 reason is working with different projects simultaneously. Working with a master plan project but am only using slabs and wall and zones not going into details yet but really zooming in zooming out it will take an amount of time that shouldn't happen.
Wondering if something is not working right or am I doing something wrong... 😒
WINDOWS 11 PRO
ammacdon
This might have something to do with Electron in Tahoe, see here:
https://furbo.org/2025/10/06/tahoe-electron-detector/
This little utility showed the following apps as potential sources of slow-downs:
❌️ BIMcloud Server Configurator.app (24.3.0)
❌️ BIMcloud Server Restore Tool.app (24.3.0)
❌️ BIMcloudMonitor.app (24.3.0)
❌️ BIMx.app (37.2.0)
❌️ BIMcloud Manager Configurator.app (24.3.0)
❌️ BIMcloud Manager Restore Tool.app (24.3.0)
