ivorhession
Archicad Solo Download
Hey All,
I might be being really thick here but!
I have a new computer and i need to transfer Archicad onto it (it will be the UK verision) - but i cannot find the link to the download Solo for either 24 or 25?
Can anyone please point me to where it might be?
Cheers
Ivor
Ivor Hession
Principal
tóg_architecture
www.togatchitecture.com
AC28 Solo / Windows 11 / PC / AMD Ryzen 5 / 36 gb ram / Gigabit RTX 3040 /
1 Solution
JohnJay
My bad - that link was for the update, not the install
Found this after some searching and fiddling.  Hopefully it works
https://graphisoft.com/downloads/Archicad/install/AC24Solo/UKI
edit: for some reason the forum won't let me edit the link correctly.
you need to change the upper case A (for Archicad) in the address to lower case
AC27 | i7990x | RTX4070 | W10
Go to post
11 Replies 11
JohnJay
Downloads – Graphisoft
Scroll down to where it says 'Updates for Archicad' and then change product type from 'Archicad' to 'Solo'
ivorhession
Hey, thanks for the reply.
I tried that originally, for both the 24 and 25 updates, but it wont load as there is no Archicad on the computer to update.  I just get the dialog box below:
I need to find the full program to down load!
(which i can get for the full version of Archicad but not solo)
Ivor Hession
Principal
tóg_architecture
JohnJay
ivorhession
Hey,
Thanks a million, that's it sorted.  Would have spent all day trying to find that link...
Ivor
Ivor Hession
Principal
tóg_architecture
jdetamore
Did you happen to find any downloads for AC25 Solo?  I see the update for it but can't seem to locate the main software download anywhere.   I'm upgrading to it due to the Monterey OS.    Thanks!
ivorhession
Hey,
Yes you should be able to use the link below.
https://graphisoft.com/downloads/Archicad/install/AC25Solo/UKI
ivor
Ivor Hession
Principal
tóg_architecture
jdetamore
Thanks, so much.  My searches were coming up empty for some reason, but we're all sorted now.
Kev21933
ivorhession
hmmmm they must have changed it...
Ivor Hession
Principal
tóg_architecture
