JohnJay
since ‎2020-07-12
‎2025-03-21
User Statistics
  • 146 Posts
  • 2 Solutions
  • 9 Likes given
  • 36 Likes received
User activity
Is it possible to do Daylight Analysis natively in Archicad? I have Octane Render too if that helps? Surely all the data is there and just needs to be extracted? Operating system used: Windows
I just installed AC27 INT SOLO (updated to 4031) but have an issue with text boxes I can see the text box but can't see any text. I tried with different fonts, including Arial and other standard fonts, large size and so on If I double click to edit, the text appears. If I cl...
Is it possible to update layer combinations based on the current open window combination (similar to how we can update views)? Currently I create a new combo then delete the old one but there must be a better way?
Can someone check this pls so I can understand if it's something on my end or if it's some kind of bug, or expected behaviour. The attached file is very simple - just some intersecting circles on a hidden layer and shown as Trace Reference With the TR active (circles layer T...
How is it possible that after 26 versions and many requests, a self proclaimed best in class architectural software still doesn't have a simple corner sliding door object with useful options such as pocket, postless corner and so on?
