2022-01-23 04:27 PM
Hey All,
I might be being really thick here but!
I have a new computer and i need to transfer Archicad onto it (it will be the UK verision) - but i cannot find the link to the download Solo for either 24 or 25?
Can anyone please point me to where it might be?
Cheers
Ivor
Solved! Go to Solution.
2022-01-23 06:46 PM - edited 2022-01-23 06:54 PM
My bad - that link was for the update, not the install
Found this after some searching and fiddling. Hopefully it works
https://graphisoft.com/downloads/Archicad/install/AC24Solo/UKI
edit: for some reason the forum won't let me edit the link correctly.
you need to change the upper case A (for Archicad) in the address to lower case
2022-01-23 05:53 PM
Scroll down to where it says 'Updates for Archicad' and then change product type from 'Archicad' to 'Solo'
2022-01-23 06:05 PM
Hey, thanks for the reply.
I tried that originally, for both the 24 and 25 updates, but it wont load as there is no Archicad on the computer to update. I just get the dialog box below:
I need to find the full program to down load!
(which i can get for the full version of Archicad but not solo)
2022-01-23 08:02 PM
Hey,
Thanks a million, that's it sorted. Would have spent all day trying to find that link...
Ivor
2022-02-03 02:32 AM
Did you happen to find any downloads for AC25 Solo? I see the update for it but can't seem to locate the main software download anywhere. I'm upgrading to it due to the Monterey OS. Thanks!
2022-02-03 10:15 AM
Hey,
Yes you should be able to use the link below.
https://graphisoft.com/downloads/Archicad/install/AC25Solo/UKI
ivor
2022-02-07 06:28 PM
Thanks, so much. My searches were coming up empty for some reason, but we're all sorted now.
2022-04-04 11:49 AM
2022-04-04 12:46 PM
hmmmm they must have changed it...
