ā2020-11-20 12:10 PM
| Archicad 4.5 - 29
| HP Z840 | 2Ć E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
ā2020-11-23 04:15 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
ā2020-11-24 11:41 AM
mnguyen wrote:1. Drivers should all be up-to-date. Windows native update tool says that Nvidia drivers are ok, but there is a more recent driver on the Nvidia website, which I did not install, but will do. Yes, it's Windows 10 Pro I am working v24 on.
1. I would like to make sure that all drivers, especially graphics card drivers are up-to-date.
2. If possible, could you try to run it in DEMO mode to see whether the freeze still happens?
3. At which point does Archicad freeze after the splash screen appears: at splash screen or after clicking New/Browse at startup dialog?
| Archicad 4.5 - 29
ā2020-11-24 12:11 PM
Minh Nguyen
GRAPHISOFT
ā2020-11-25 02:27 AM
ā2022-11-30 04:08 AM
The "new" start up screen is absolutely useless.
In Win 11 Archicad 25 just at Archicad 25 hangs at Logo screen
for 10 minutes before user can do anything.
This is because it tries to list all recent files including .mod files.
I figured how to clear the list, or to skip the open screen all-together, but that's a nasty workaround, not a solution.
Could we please have an option to turn Open screen with recent projects it off?
At least give us an option to NOT LIST .mod files there.
Nobody in ther right mind should ever directly open .mod files.
Users generally should not even know that .mod files exist as a phisical openable file!
ā2023-11-17 05:13 AM - edited ā2023-11-17 07:01 AM
Hi Team,
I just saw this one and thought it was worth to reply in case it is still needed. The issue occurs because the welcome list page is overloaded with projects and mods files.
I wrote a BAT file to overcome this issue with a short script that clears the list in 1 second in Archicad 23-24-25 & 26.
Just unzip and place the file in the documents folder and execute using double click on it. ( it is a text file so any one can open it it notes and edit it if you are using AC27)
One more thing... All Archicads need to be closed otherwise the script will not work
Mauricio
ā2023-11-17 05:56 AM
Mauricio, and all who commented:
The suggested workarounds are great, but they are Workarounds!
Why can't GS simply give us an option sg like a tick box list where users can select which file types they want visible in the start up list?
As for me: I never ever ever want to see mod files in startup. I dont even want my team to know it is possible to open a mod file!
In our projects we often have hundreds of mods. They should not be listed in the Archicad startup window as editable files!
