2020-05-14
06:49 PM
2024-01-30
10:18 AM
Aruzhan Ilaikova
2020-05-18 07:32 PM
Lingwisyer wrote:
There were some other posts that mentioned something about forcing AC to use your dedicated GPU / disabling the integrated GPU.
Here is a thread on the MS forums about how to do it;https://answers.microsoft.com/en-us/windows/forum/all/is-there-a-way-to-force-a-program-to-use-a/fab...
2020-05-18 10:30 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-05-19 10:37 AM
mnguyen wrote:
Hi PatriziaTR,
Thank you very much for sharing the issue and I am very sorry about the experience!
From your description, I believe that you should have a Bug Reporter dialog appear after the crash. Did you manage to send the crash report to us via the Bug Reporter? If yes, could you please send me the bug IDs for checking? It may reveal what made ARCHICAD crash under the hood!
If you didn't write down the number, it can be found in a file calledSubmissionLog.txtin C:\Users\<user>\GRAPHISOFT
If you did not send the crash report, could you please go through the process again and send me the bug ID for checking?
Best regards,
Minh
2020-05-19 10:54 AM
Minh Nguyen
GRAPHISOFT
2020-05-19 12:53 PM
mnguyen wrote:Dearest, I did what you suggested and the bugID IS : AC23-2020-05-19-12-48-43-7842.
Thank you for the information!
Unfortunately, from this report, it does not provide enough information to find out why the crash happens. Could you start ARCHICAD again and let it crash, send the report to GRAPHISOFT through the Bug Reporter and send me the bugID, that should look like this: AC22-2020-05-xx-xx-xx-xx-xxxx (with x is a number)?
Thank you very much!
Best regards,
Minh
2020-05-20 08:48 AM
Minh Nguyen
GRAPHISOFT
2020-05-20 10:54 AM
mnguyen wrote:
Thank you for the information! ARCHICAD working in DEMO definitely suggests that something is blocking ARCHICAD from looking for the license. Could you completely remove the anti-virus program (Norton in your case), start ARCHICAD and enter the student license and see if ARCHICAD can successfully start? I understand that it might be time-consuming, but this is necessary to make sure that the AV program will not mess with ARCHICAD startup process.
Let me know how it goes!
Best regards,
Minh
2020-05-21 08:20 AM
Minh Nguyen
GRAPHISOFT
2020-05-23 07:21 PM
2020-05-25 09:51 PM
Minh Nguyen
GRAPHISOFT
