‎2013-11-03 12:11 AM
‎2013-11-03 09:22 PM
‎2013-11-03 11:11 PM
‎2013-11-03 11:36 PM
Karl wrote:Thanks - I've updated my signature to show the correct AC 17 info.
This is more of a hardware issue, so I've moved it to this forum.
Your signature says you're on AC 12. If that's the case, then you won't see a solution. I you're on 16 or 17, let us know.
‎2013-11-05 11:30 AM
‎2013-11-05 11:10 PM
vistasp wrote:I gave it a try and set the registry value to my screen dpi (275) but it did not appear to have any effect at all. Thanks for the idea though!
Chris, if you're comfortable tinkering with the registry, you can experiment with the setting given in this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=215183
Do let us know what you find.
‎2013-11-06 12:38 PM
