2022-01-13 11:09 PM
I'm upgrading to Archicad 25 on windows 10 on a new computer. Archicad installed alright and it works, but
2022-01-15 06:48 AM
Sounds like either the key has become corrupted (damaged) in some way, or the USB port is not working.
Try a different USB port.
If you have the License Manager Tool on another computer, you can try upgrading the key there.
I assume the key used to work with you previous version (24?).
Is that still the case - can you still run your previous version with that key?
2022-01-20 11:00 AM
Thank you very much for the question!
What Barry has suggested is a pretty good start. I'm wondering if you have tried it?
Generally, if Archicad can run with the key, then the problem might come from the License Manager tool. I'm wondering if you are trying to update from Archicad 24 to 25 or something else?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
