Installation & update
ArtLantis 4.5 on multi user ( classroom) mashines.
Hi.
We are using Archicad 9 and ArtLantis 4.5 for a class with 15 students.
We are deploying the programs as a part of a Ghost image, meaning all machines are identical.
Can run both ArchiCad and ArtLantis as local administrator ( the same account as used to create the original master machine > ghost -image.
Two problems
-we have to set the wibu-key for every student as they are logging in the first time. Solved this by running a reg.file by starting the program, described in a previous tread.
- For ArtLantis 4.5, we have to type the serial number with the CD-in the reader for every machine and user of that machine.
Any work around for this???
PS. anyone that made msi packages of ArchiCad?
-- Sven-Erik Tiberg --
Lulea Univ. of Techn..
Sweden.
1 REPLY 1
Have you contacted Abvent technical support or posted your question to the Artlantis (Abvent) forums?
http://www.abvent.com/support/forum/list.php?f=11
I have a feeling you'll have to do the serial number for each machine, but am surprised you have to do it for each user. Artlantis 4.5 also has a copy protection feature that randomly (and not very often) asks that the original installation CD be inserted.
Good luck with your class!
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
