BIM Experience Kit - ITG, Chapter 2, 2.1 Creating Exterior W
Can anyone explain to me. I've been going through the exercise and I don't see the purpose of the operations "Explode into View" applied to the placed drawing, and "Ungroup" elements in Worksheet. First of all when I apply the EICV command I observe no change (except colour), and as far as I can see neither operation makes any difference to the subsequent operation of creating walls from the Trace Reference.???????
Phil
I actually worked on this Interactive Training Guide.
First, to answer your question: normally, there is no need to explode the Drawing containing the DWG lines and fills. So that step could be skipped.
However, the reason it was done this way is so that it can be replicated by users. The cursor senses the nodes and edges of elements within a Drawing. But in that case I found (if my memory serves me right) it was not reliable for some reason. So I had to come up with a way so that it can be done.
This is an interesting aspect of creating training materials: you have to create them in a way that the users can re-create them from your instructions because you will have no chance to explain why something does not work, if that happens. So it has to be foolproof.
