filip
BIMcloud basic backup not working
Hi, I need help with performing backup for BIMcloud basic.
I've encountered a problem with my BIMcloud. I've accidentally uninstalled everything without performing a backup first.
So I've managed to pull everything back with the data recovery program, and I've followed the steps from this guide https://community.Graphisoft.com/t5/Teamwork-articles/BIMcloud-Backup-Guide/ta-p/303858
I've copied all the folders from the 2nd level description, but projects and users are not visible in my new installation of BIMcloud.
Why? Can anyone help?
Thanks
1 Solution
filip
So, I've managed to pull out the data from the PCs that were connected to the project. I went to each PC and opened a project in offline mode, then save as pln solo file and after that uploaded that pln to the new BIMcloud and that's it.
Go to post
2 Replies 2
filip
I didn't have a lot of projects there, so at one point I've made some backups, and only for one project I don't have a local backup.
Is there a way to somehow get a .pln from the local data or somehow from the Projects folder on the server?
Users are also not important right now, only that one project.
filip
