Haneef Tayob
BIMx - constant crashing
I notice that I cannot open most of my BIMx models on an iPad unless I simplify the BIMx model by turning off some of the items (for example trees layer). Sometimes I also have to keep global illumination uninitialized.
My BIMx files are often 80mb in size.
Any suggestions.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Simplify the model, as described here:
http://www.graphisoft.com/support/bimx/optimization/
Using the Polycount add-on to reduce the detail of all objects is a good start. In the model I published, which is fairly large and includes MEP, reducing the detail of objects produced a very light BimX file:
https://m.gsbimx.com/ModelDetail/LoadDetails/141
David Collins
Material texture bitmaps also eat up a lot of memory. Check your materials for large bitmaps. A more extreme solution which I'm considering for use when trying to get large models into BIMx : temporarily swap in a duplicate set of materials with ALL the bitmaps deleted.
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
