Installation & update
Broken view
Dalius
The Floor Plan view breaks and 3D Window view blinks (and sometimes it becomes grey) when a mouse wheel scrolling (zoom in/out). Where is a problem? Attached is an example of what is going with the Floor Plan.
Dalius Regelskis
Archicad user since version 6.0
https://archicad-pamokos.lt
5 REPLIES 5
Does it stay that way after you refresh the view (CTRL+R)?
This is a problem that has plaqued AC since v10. It is very annoying. It goes away, for some reason, if you save the document, but it will appear again. Trust me.
I used to experience that a lot when I had a slow graphics card on my machine. Since upgrading I haven't seen the problem again.
What are your hardware specs, aadler?
Brett Brown
Do a search for "split screen", this has been discussed before. Nothing seems to fix it,and the trigger for me is Windows Media Player in a session,even before Archicad is open. Only fix is a restart and not using WM Player. Have reported it to Graphisoft, and there response was Vert sync off (which it is) and latest video card drivers (which it is).No help.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
I have a Penryn MBP with a 512 MB Geforce 8600, so the card should handle it. And it happens on all our macs, so it can't be associated with WMP - we don't have it installed.
