Dalius
Broken view
The Floor Plan view breaks and 3D Window view blinks (and sometimes it becomes grey) when a mouse wheel scrolling (zoom in/out). Where is a problem? Attached is an example of what is going with the Floor Plan.
Dalius Regelskis
Archicad user since 6.0
https://archicad-pamokos.lt
5 Replies 5
Does it stay that way after you refresh the view (CTRL+R)?
This is a problem that has plaqued AC since v10. It is very annoying. It goes away, for some reason, if you save the document, but it will appear again. Trust me.
I used to experience that a lot when I had a slow graphics card on my machine. Since upgrading I haven't seen the problem again.
What are your hardware specs, aadler?
Brett Brown
Do a search for "split screen", this has been discussed before. Nothing seems to fix it,and the trigger for me is Windows Media Player in a session,even before Archicad is open. Only fix is a restart and not using WM Player. Have reported it to Graphisoft, and there response was Vert sync off (which it is) and latest video card drivers (which it is).No help.
I have a Penryn MBP with a 512 MB Geforce 8600, so the card should handle it. And it happens on all our macs, so it can't be associated with WMP - we don't have it installed.
