Bug report with ArchiCAD 12 on MacBook Air v.10.10.1 OS X Yosemi
I just installed ArchiCAD 12 on my MacBook Air v.10.10.1 OS X Yosemite (128 GB) per a link from Graphisoft, because I cannot find my software CD. Anyways, When I try to open ArchiCAD 12 it immediately opens a message that states it had to close unexpectedly and to reopen or press OK. I also have ArchiCAD 14 installed as I need both for different users I work with. I tried restarting my computer but still get the message when I try to open ArchiCAD 12. I can open and work in ArchiCAD 14 no problem.
Here is the report with this shutdown message:
Process: ArchiCAD [359]
Path: /Applications/Graphisoft/*/ArchiCAD.app/Contents/MacOS/ArchiCAD
Identifier: com.graphisoft.ArchiCAD
Version: 12.0.0 (12.0.0.2325)
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: ArchiCAD [359]
User ID: 501
Date/Time: 2014-12-10 12:49:02.787 -0800
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: 718B7394-1473-2FE0-6F0B-E1DFFF887027
Time Awake Since Boot: 86 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000000001000-0000000002054000 [ 32.3M] r-x/rwx SM=COW /Applications/Graphisoft/*/ArchiCAD.app/Contents/MacOS/ArchiCAD
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.graphisoft.GSRoot 0x03a93252 mach_override_ptr_with_allocator + 84
1 com.graphisoft.GSRoot 0x03a93534 mach_override_with_allocator + 104
2 com.graphisoft.GSRoot 0x03a93564 mach_override + 46
3 com.graphisoft.GSRoot 0x03a935a6 InstallRTTIIssueLogger(void (*)(std::type_info const&, std::type_info const&)) + 64
4 com.graphisoft.GSRoot 0x03ac6926 BugRepMac::BugRepMacAutoInstall::BugRepMacAutoInstall() + 94
5 com.graphisoft.GSRoot 0x03afbef4 __static_initialization_and_destruction_0(int, int) + 138
6 dyld 0x8fe660b3 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 291
7 dyld 0x8fe66218 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 64
8 dyld 0x8fe622f0 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 296
9 dyld 0x8fe62288 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 192
10 dyld 0x8fe62176 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 120
11 dyld 0x8fe623e1 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 79
12 dyld 0x8fe54125 dyld::initializeMainExecutable() + 183
13 dyld 0x8fe57bad dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 2793
14 dyld 0x8fe53232 dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*, unsigned long*) + 428
15 dyld 0x8fe53047 _dyld_start + 71
Model: MacBookAir6,1, BootROM MBA61.0099.B16, 2 processors, Intel Core i5, 1.4 GHz, 4 GB, SMC 2.12f143
Graphics: Intel HD Graphics 5000, Intel HD Graphics 5000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.15.124.12.10)
Bluetooth: Version 4.3.1f2 15015, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD TS0128F, 121.33 GB
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: WIBU-BOX/U
Thunderbolt Bus: MacBook Air, Apple Inc., 23.6
Please Advise.
1 Reply 1
If you need AC 12 and 14, you should not be running Yosemite:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-10-yosemite/
ArchiCAD 12 and older versions cannot run on OS X 10.10 due to technical limitations.
