Build 1200
Hi all,
I need to upgrade to build 1210 however cannot find build 1200 anywhere - can somebody please help me with its location.
Thankyou
7 Replies 7
Rod Jurich
Orbit wrote:
/......cannot find build 1200 anywhere/.....
Ian, you can update using build 1210.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
__archiben
1210 is just a patch and requires the full 1200 build already installed. you can find the link to 1200 on the 1210 download page . . . if i recall correctly...
cheers
~/archiben
b e n _ f r o s t
David Maudlin
Ian:
You can also try Help > Check for Updates...
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin / Architect; We did this about 2 weeks ago. So this will be fuzzy. Indeed you need build 1200 before installing 1210. On the 1210 download page, where they tell you that you must have 1200, there is an obscure link, it does not say down load 1200 or anything like it. Check ALL of the links on that page, one will take you to a download page with 1200. Sorry I can't offer more, I see the page dimly in my dim mind but can't remember what it is labeled.
good luck
I found the link to download Build 1200 under the release notes for build 1210. I guess they say read carefully for a reason.
AH YES! Release notes. now it is all coming back.
Thanks to everybody for your help, can you believe I actually read the release notes and must have just glazed over when I read the part where it said click link below to download build 1200!!!!!!!! What can I say?
Thanks again
