Installation & update
Build 1965
Erika Epstein
I noticed there is an update for ArchiCAD, at least in the US.
(I like this new direct link to updates under the help menu)
Anyone try it?
Any Problems?
thanks,
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
6 REPLIES 6
Aussie John
i havent noticed anything yet but I am on Mac so comment probably not relevant
Cheers John
[/size]
Stephen Dolbee
We've been using it for over a week now. So far, no problems.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Steve
Steve,
I, personally, have been cautiously waitng to do this update. Can you verify if the "stories settings bug" in the following thread shows up in your verion of build 1965?
http://archicad-talk.graphisoft.com/viewtopic.php?t=5547
Thanks,
Dan K
Stephen Dolbee
Dan,
I just checked. Under "image menu/elements to show in 3d" the main level is shown as story 1. Under "options/stories" it shows as story 0. Everything seems to work ok, though. I don't know how it was in the previous build, but I think this is more an inconstistancy, than a bug.
Steve
Ben Odonnell
So far so good.
Have been using it since it came out last week and it seems fine. The only thing to watch out for is on the MAC version. If you have changed the ArchiCAD program name, eg ArchiCAD US (18..) , you will need to change it back to it's original name other wise it will cause problems for you.
There is a thread floating around but I can't seem to find it.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Get your BIM objects from bimobject.com
Ben Odonnell
Found it http://archicad-talk.graphisoft.com/viewtopic.php?t=5501&postdays=0&postorder=asc&&start=0
Ben O'Donnell
