Build 2256 Library Update
On the tr.graphisoftus.com website, there is a 75 mb update posted on 4/15 to upgrade the Archicad 8.1 library to include the Roofmaker subfolder.
I downloaded the 75 mb file and when I went to install/upgrade, it failed stating a CRC corrupted file.
Does anyone have experience with this.
Thanks, Grant
2 Replies 2
Grant,
When I installed the build 2256 ArchiCAD Library 81.pla I extracted it
and noticed that the RoofMaker library parts were floating around in the object library not in a sub-folder.
This condition makes them non-accessible by the object tool.
I did the following and it seems to work.
In my hard drive directory I created a folder called RoofMaker Library 81
and put it inside the ArchiCAD Library 81.lib folder, I gathered up
all of the RoofMaker library parts and put them into this folder.
I have not seen the update but I believe this is what GS has done.
The Roofmaker parts are now accessible by the object tool
and Roofmaker still works.
HTH,
Peter Devlin
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
CRC corruptions often occur when one downloads files from the internet. I tried to download the file in question myself and it worked for me, so what you experienced should have been an occasional error of the download process. I think that you should try download the file once again.
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
