2012-11-1509:34 AM - last edited on 2024-03-2811:10 AM by Aruzhan Ilaikova
C4D addon instalation issues
2012-11-1509:34 AM
I have an error running C4D add-on instalation: "Java Runtime Enviroment in your system is outdated... " although when I check for an update on java.com it says that I'm up to date. Any ideas how can I fix that ?
Before installing ArchiCAD and its Add-Ons, you should install the Java version that was bundled with the ArchiCAD version you have.
On the ArchiCAD installer DVD there is a Java folder that can be used, or you can find the Java installers here: http://www.archicadwiki.com/Install/Java
