Installation & update
C4D addon instalation issues
I have an error running C4D add-on instalation: "Java Runtime Enviroment in your system is outdated... " although when I check for an update on java.com it says that I'm up to date.
Any ideas how can I fix that ?
Thanks
1 REPLY 1
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Dear JKurt,
Before installing ArchiCAD and its Add-Ons, you should install the Java version that was bundled with the ArchiCAD version you have.
On the ArchiCAD installer DVD there is a Java folder that can be used, or you can find the Java installers here: http://www.archicadwiki.com/Install/Java
I hope it helps.
Katalin Takacs
