pnrthomp
ArchiCAD 28 silent installation issue
I keep running into an issue where Archicad ver. 28 doesn't install properly. The logs show this:
08:12:32] Unknown error while running C:\Program Files\GRAPHISOFT\License Manager Tool/GSFWConfigurator.exe -action add -path "C:\Program Files\GRAPHISOFT\License Manager Tool\GRAPHISOFT License Manager Tool.exe" -name "License Manager Tool 20.0" -direction in -enable true -traffic block
[08:12:32] Installing WIBU driver...
[08:12:32] Executing C:\Program Files\GRAPHISOFT\License Manager Tool\WIBU64\Setup64.exe
[08:12:44] Script exit code: 0
[08:12:44] Script output:
[08:12:44] Script stderr:
[08:12:44] Executing C:\Program Files\GRAPHISOFT\License Manager Tool\GRAPHISOFT License Manager Tool.exe /REGISTER
[08:12:44] Script exit code: unknown signal
child killed: unknown signal
[08:12:44] Error running C:\Program Files\GRAPHISOFT\License Manager Tool\GRAPHISOFT License Manager Tool.exe /REGISTER: child killed: unknown signal
Some files and folders are created, but it's not usable. I have to perform this remote installation via the command line as I don't have physical access to the systems and RDP isn't an option.
Any help is appreciated.
0 Replies 0
