CAN'T INSTALL ARCHICAD 22 UPDATE (4005)
Hi guys,
I got a problem when trying to install the ArchiCAD 22 update (4005) like the image attached below. Even I already chose the right folder that ArchiCAD 22 been installed. Could anyone help me please?
My version is ArchiCAD 22 (3004) and I'm trying to update to (4005).
Thanks,
The update needs to be for the same language version as your Archicad program.
i.e. if you Archicad is the INT version, then you must update with the INT version as well.
Try to update with the latest hotfix, which is AC22 b6021.
