Cadimage Window/Door Builder Question
Stress Co_
Anyone using Cadimage Door/Window builder know which setting removes the door threshold line? (see attached)
I can set the pen to one which doesn't print, but it seems, it's the same pen for the door panels (so then, the door panels don't show in elevations).
Marc Corney, Architect
Red Canoe Architecture, P. A.
13 REPLIES 13
__archiben
under 'Symbol'>Plan View Items.
turn 'Threshold Contours' off.
~/archiben
b e n f r o s t
Stress Co_
Ben: Does it work for you?? I tried it but still see the threshold (in the preview and on the plan)?
__archiben
it does. but it also looks as though you have an earlier DWB version? you don't have the full extent of options available as i have - where the sill display and threshold display are treated as separate plan view elements . . .
~/archiben
b e n f r o s t
__archiben
another thought: what are your 'master contours' settings?
~/archiben
b e n f r o s t
Stress Co_
DoorBuilder 35 for AC10?
Stress Co_
~/archiben
Same as you show.
__archiben
door/window builder 35 10.6 released 13th september 2006. lots of enhancements and defects corrected . . .
~/archiben
b e n f r o s t
Stress Co_
I can't figure out where to find which build I have.
__archiben
look in your cadimage library from the finder:
inside the 'DWBuilder 35 for AC10' folder is a file called 'DWBVersion.txt'
~/archiben
b e n f r o s t
