Cannot read plan file/Repair process failed/
Hello
Hibaüzenet nélkül elmentettem egy fájlt. Másnap nem tudom megnyitni. Se a pln, se a bpn formátumút. Másik gépen, másik mappában sem. Hogyan tudnék hozzáférni egy heti munkámhoz, ami így bentragadt a fájlban, legalább részlegesen?
I saved a file, normaly, with no error message. Next day I cannot open it. Neither pln, nor bpn. Neither tried on other maschine, nor from other folder. How could I get acces to my work, that closed to this broken file? At least partially?
11 Replies 11
I am having same problem, and failed to recover as well. I am connecting with Archicad technical support. any one solved the problem?
That 'can not read plan' message can mean that you are trying to open a newer version file (say 23) in an older version (say 22).
If you open through the FILE menu in Archicad, the open dialogue box will show you the file version when you select it.
