Check File Version
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-11-16 11:55 PM
Hi all,
Just wondering how we can determine the Archicad version for a file in explorer.
We have versions 22, 24 ,26 installed and projects are running across all versions.
In the file explorer, is there a way to see properties or something else that can tell me what version it is.
Normally, we just try opening it in the lowest version (22) and if it doesn't work we move to the next one. (24 then 26)
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-18 06:46 AM
Also in Windows File Explorer, if you right click on a file and open the 'Properties' information, you can go to the 'Info & Preview' tab and it should show you the Archicad version it was saved with.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-17 12:25 AM
I’m not sure if windows has an equivalent but on a Mac you can select the file and spacebar to show a quick preview and that gives the file version. Properties of the file may display it in windows. We also use a file naming convention which includes the Archicad version but this relies on the user chagrin it manually.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-17 01:15 AM
We use Windows and in the properties tab, it shows 'opens with', but that is just the default I have set to open *.pln files. So even for an older file, it will show ''opens with AC 24.0''.
I suppose the option to start adding it to the file name might be worth the effort. A tiny bit of effort will save time second guessing and doing trial and error later on.
Thanks for your answer though!
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-17 02:45 AM
Try hovering the mouse over the file name in your Windows Explorer.
That usually give a pop-out that shows the file version.
Or open Archicad and use the FILE > Open dialogue.
At the bottom right side you will see the file version if it is the same or older than the version of Archicad you have open.
If you select a newer file, then it will show nothing if that is the first file you select, but will show the version of the previous file if you have selected another file first.
So this is not fool proof.
Also there you can hover over the file and you will see the version.
If it says version 0.0, then it is a file that belongs to an newer version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-20 11:36 PM
This works!
Hovering cursor over file only shows "Archicad Solo Project" for me. But the properties tab does it.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-11-21 05:24 PM
if it does not work, it can be activated afterwards. You must run the script as administrator.
