Installation & update
Codemeter enabler not registering AC11
David Bearss
Recently installed a new hard drive and thus reinstall all programs. Have upgraded to AC18 and still migrating From AC11. Following the instructions for the AC11 codemeter enabler but AC11 not recognizing Codemeter. Instructions are impossible as they say; "Do not remove the WibuKey driver from your system. Both CodeMeter and WibuKey drivers need to be installed."
Not possible as WIBU key was returned to Grapisoft. How are we supposed to activate? Anybody found a workaround?
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
4 REPLIES 4
On your AC11 disk you should have a "WIBU" folder that has the setup files for the WIBU drivers.
These should get installed when you install 11 but they can be installed separately.
Sounds like you then need to install the Codemeter enabler as well.
You won't need the green WIBU key anymore - just the drivers.
Have you checked your Codemeter key with the License Activation program to ensure it has been programmed with your 18 license.
New keys are usually supplied with no actual license on it.
David Bearss
Totally frustrating waste of time. Graphisoft explanation on this is cryptic at best. Process that finally worked;
Uninstall java.
Install java 6 from AC11 CD.
Update AC11.
Install WIBU driver from AC11 CD.
Install enabler.
Simple enough once the wiji board step process is figured out.
Barry thanks for the help.
David Bearss
Alienware 17 R5
How do you check to see what licenses are on the Codemeter?
I found the answer to my own question. The link for the License Management Tool is here: http://www.graphisoft.com/downloads/licensing/help/INT/pc.html
