Compatible mouse with Archicad 26
Paa
I recently purchased a 3D CADmouse from 3Dconnexion and just could not get it configured to work with Archicad 26, specifically the scroll wheel to orbit my 3D images as well as could not assign a function to my middle button. Called their tech department and they told me that it may not be compatible with this version of AC. Currently running on MacOS Catalina 10.15
Anybody else have this problem?
Also, any recommendation on mice?
13 REPLIES 13
i've installed it on PC. i'm not on a Mac. so i don't really know the particular settings for the mouse in that OS.
i'm guessing you've been flicking between the various tabs? Device/Buttons/Radial menus/Macros/ and Tools? & nothing in there that you can tell the device to register these particular commands while Archicad is the active window? i'm guessing the device is compatible with the macOS seeing as you've got it installed?
if no one else here can help, perhaps the ol' Professor Google?
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
Jose Gradoli
MX Master, 2S, 3 or 3S for most compatibility with latest Logi Options app
www.formaarquitectura.com
ARCHICAD 25 SPA
Cool ! I am glad you got this problem sorted.
I am very interested in purchasing the 3Dconnexion cadmouse pro wireless to use on AC24 7006 AUS with macOS 12 Monterey. I am not sure if it will work properly on it, since it is only supported for Bluetooth only at present ?
Any tips will be helpful thanks.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
mthd
I bought a new unused cadmouse wireless from eBay everything works just fine with windows 10. It’s very comfortable and smooth, easy to use.
I have a Mac with OS 12 Monterey and I can only get the mouse pointer moving with the cable and or via the USB dongle. No mouse clicks are registering on the Mac and I have tried connecting it with Bluetooth but the mouse is not being detected. The blue Bluetooth light flashes on the mouse but the mouse is not being detected ?
Has anyone been able to get one fully working with Mac 12 or higher ?
Edit: I found a solution to be able to get my cadmouse wireless working on my Mac Monterey since it was an older model from 2017 but new and unused.
Please see this link below from the 3DConnexion website. My firmware needed to be updated to Version 1.11 or higher and this link will show you how to get around it in Mac with the security settings etc. all works fine now apart from being limited to 4 radial commands instead of 8.
https://3dconnexion.com/uk/support/faq/cadmouse-cadmouse-wireless-doesnt-click-macos/
