Installation & update
Curtain Wall Tool
ares997
Curtain wall tool crashes when editing the scheme and the second button is selected. Though overall I've been crashing a lot in curtain wall tool.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
ares997
Why can't you adjust the door sizes in the curtain wall tool. Are you just supposed to set the panels to have the size you want in the frame and then add more frames?
You can't use the shift lock in the curtain wall tool to get a distance off a frame them move it. You can't set the origin point either.
This tool seemed good until the need for a door to be a certain size or adjusting the scheme lines.
ares997
When the z-tracker is checked it theoretically should show up. But even when it is selected and un-selected and re-selected it doesn't show.
