Nick Spy04
Drag & Copy not working all of a sudden
Hi There,
Need help with a technical problem. All of a sudden, my drag and copy shortcut is not working. I have tried opening multiple files and uninstalling and reinstalling and still the same issue. I asked my team if they are having the same issue and one member in my team has said yes. Was wondering is this a glitch, can someone help.
Using ArchiCAD 25 AUS (Build 6000) (Full)
Thank you.
1 Reply 1
Check your Work Environment to see that the keyboard shortcut is as you expect.
If it is, then you may have another program running in the background that is hijacking the keyboard commands.
