Dual Core Dragging
I have noticed that my newer dual core machine is slower than my older single core machine. It has been bugging me since I switched to AC10 from AC9. I think I may have finally found the source of the problem. When one open instance of archicad is allowed to access both cpu's the cpu usage goed to over 50% even at rest. When I set archicad to use one of the cpu's the cpu usage goes to 0% at rest as it should.
On my single processor machine the cpu runs as it should.
The dual core unti had been running at 50%+ usage all the time on both cpu's causing serious lag. I am wondering if anyone else sees this sort of effect on their dual cores? Maybe it is specific to my smithfield chips.
5 REPLIES 5
TomWaltz
Are you using the PPC or the Intel version of Archicad 10?
Tom Waltz
Oh, I am using a pc-dell. Core duo. 3.0GHz.
I agree. It seems a duo will top out at 50% of your CPU usage.
Everything is working exactly as it should. See:
http://www.archicadwiki.com/Multiprocessing
where this exact question is asked. (Comes up on this forum every week, as well...)
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
My situation isn't right. My processors run at over 50%-100% (closer to 100%) when archicad is the only software open, causing serious bottleneck, even at rest. I have recently found that if I open photoshop first and then Archicad, the processors run normally. When I shut photoshop down the processors run up and over 50% and slow down archicad.
I think it may be my pentium D dual core cpu. I have been hearing that there were some issues with the d-series as far as bottlenecking... Or maybe photoshop is forcing Archicad to use the Video Card and lightening the load on the cpus. I am not sure what is happening exactly.
For now I am keeping a photoshop file open and then archicad runs swiftly.
