lapishawaii
ENCAD CADJet2 on OS 9
Sorry I was not able to place this reply under the same heading but the reply button refused to open a reply page. I'm able to open a reply page for any other subject on the web site, but not this one. I just get kicked back out to the general subject page. Go figure!
I assume you're using ArchiCAD 8. To set up the spool folder is quite simple. First, create a "Spool Folder" on your server. Then in PlotMaker go to Publisher. Select the View Set you want and highlight the document sheets in the menu below. Open the Plot Settings dialog box. Under Destination select the Spool Folder button. Next click on the Plot Setup button. You will see a Spool Folder box. Click on the Select button in this box and navigate to your "Spool Folder". You should then be set to go.
0 Replies 0
