Encad CadJet 2 Mac OS X ArchiCAd 8.1
Has anyone had any luck getting ArchiCAd 8.1/Mac OSX to plot using the EnCad CadJet 2?
4 Replies 4
Yes, I don't remember who it is, but there is already a topic on this subject. Try searching the guide for CadJet 2.
The only Encad Cadjet 2 references I see are using Mac OS9.
Perhaps I am mistaken about the OS X compatibility. I only had a short and frustrating experience with the plotter long ago in OS 9.
You can always dedicate an old Mac as a plot server running OS 9 and PlotFlow. As I recall this is how we set it up way back when.
I would also strongly recommend that you try to find a way to get a new plotter/printer. The CadJet lacks the ability to print bitmaps and as I recall it also did not support the background empty fill (I might be wrong about this).
lapishawaii
I've been using an Encad CadJet 2 for over 8 years and it's still working fine with ArchiCAD 8.1. My workstations are G4's using OS X.3. However, the CadJet 2 requires a serial port so I use an old beige G3 as the plot driver. All of my drawings are sent to a spool folder on the G3 over an ethernet network. This setup works great. The CadJet 2 is not all that fast, and it can not print photo images, but it is a very reliable printer.
