Can't print from my laptop
I've installed ArchiCAD 8.0.0 R1 on my home computer and on my laptop. The laptop is a pentium 4 with 456 mb of ram but when I run plotmaker 3.0 I can't get the page set-up to open.
I'm on a ethernet router at home and my printer is going through that. I can get page set-up to open on my home computer with no problems and I can print anything else from my laptop through the router, even when I print from archiCAD. When I try to open set-up in plotmaker it just flashes and nothing happens. When I try to print I get a message that says insufficient memory.
Help needed please as I've tried everything I know.
channy wrote:
I've installed ArchiCAD 8.0.0 R1 on my home computer.
Can't help with the print issue ... but 8.0R1 was incredibly bug-infested, so I hope that you meant to say 8.1R1+ (with the downloadable bug fixing patch installed). If you really mean 8.0 because 8.1 hasn't been delivered to Oz yet ... then do install R3 and try again.
Sorry I can't help more though...hopefully someone with the real answer to your question will jump in.
Karl
Aussie John
8.1 v1 is available in oz and there is no reason not to upgrade
Cheers John
[/size]
