mrsneuna
Enscape 4.3 Not Showing in Archicad 29 – Missing Enscape Plugin
I recently installed Enscape 4.3, but it does not appear in Archicad 29.
I have checked the Window > Palettes menu and the Enscape toolbar, but there is no Enscape option available. When I start Archicad 29, I also get a message saying that Enscape is missing.
Does Enscape 4.3 support Archicad 29? If it does, how can I properly install or register the Enscape plugin for Archicad 29?
I need to use Enscape for rendering urgently, so I would really appreciate any help or guidance on how to get it working.
3 Replies 3
scottjm
Mentor
If you go to the addon manager, does Enscape site in the list?
If not you can manually try to add the addon file located in the Enscape Program files install folder (if you are on windows)
mrsneuna
Thank you. I checked the Enscape installation folder, and I found the Archicad plugin files, but they only go up to Host27.apx. There is no Host28.apx or Host29.apx.
I'm using Archicad 29. Should I manually add the Host27.apx file through the Add-On Manager, or is Enscape 4.3 simply not compatible with Archicad 29?
I don't want to add the wrong plugin version. Could you please advise me on the correct way to get Enscape working with Archicad 29?
scottjm
Mentor
Sorry for the confusion.
Looking at the release notes Enscape 4.13 added support for Archicad 29.
https://documentation.chaos.com/space/ERN/219086878/4.13.0+Windows
So you would need to update your Enscape installation to this version or higher.
