mrabercrombie
Error Codes
Hey Folks,
Can anyone shed any light on the following error codes:
Polygon is degenerated. (TR - 068)
Wrong projection code value (TR - 017)
Polygon is degenerated. (TR - 061)
Cheers in advance!
OSx 10.6.8
3.06 GHz Intel Core 2 Duo / 6Gb Ram
Archicad 17, Archicad 17 Solo + Artlantis 4 Render
2 Replies 2
Polygon is degenerated may happen when you set parameters to an object which causes a body in the GDL model to become degenerated because e.g. two nodes of the body are at the same position or the hole in a polygon is outside the contour of the polygon etc.
The other one I don't know.
However, the code in the parantheses is the ID of the affected element. So you can use Find & Select in 2D or 3D to find the element with that ID and find the problematic parameter or redo the element if it is not a library part. There may be more than one elements with the same ID.
mrabercrombie
Ah brilliant! Had no idea I could search by Element ID. The culprits were a few inverted meshes which have now been sorted!
Excellent, thank you!
OSx 10.6.8
