Installation & update
Error in russian version Archicad 27 Help
AFranch
AFranch_0-1710141434130.pngError in russian version Archicad 27 Help
Noemi Balogh
Thank you for the report. I have some good news - our team responsible for the Archicad 27 Help fixed the problem by now.
Noémi Balogh
Senior Community Expert, Admin
4 REPLIES 4
I suppose Graphisoft might fix this some day.  But, currently, Russia is under sanctions for its invasion of Ukraine and there is no support for Archicad and no new or renewing licenses there.
The Russian-language version is bought in seven countries around the world. Anti-Russian sanctions have nothing to do with it. And Grafisoft continues to release Russian-language versions even after the announcement of sanctions.
AFranch
Mistakes make no one happy. Moreover, this is not just a spelling mistake, but an incorrect command indication
Noemi Balogh
Noémi Balogh
Setup info provided by author
