Failed to launch archicad 10 program
I am a license user of archicad 10, & working for a month now, then suddenly I can not launch my archicad program, as of this date 16 Oct'07.
I tried to re-install the program but it did not work. if anyone could help me about this, I will be very thankful, make me work again with my program
3 Replies 3
Dwight
Exactly a month, you say?
Sounds like you are using a trial version.
Does the screen say anything about a hardware key?
Plugged into a USB port?
Now that the trial period is over, you'll need the key to operate.
Dwight Atkinson
NO I AM NOT IN TRIAL PERIOD, THIS IS A LICENSE SOFTWARE. ONE MONTH MEANS, WORKING ON CERTAIN PROJECT ON ARCHICAD PROGRAM, THE SOFTWARE WAS BEEN PURCHASE FOR ALMOST A YEAR NOW. I WAS ORIGINALLY WORKING IN AUTOCAD AND THIS IS THE ONLY TIME I TRIED WORKING ON ARCHICAD AFTER TAKING SOME ARCHICAD TRAINING. EVEN THOUGH YOU DON'T HAVE THE WIBU KEY PLUG INTO USB PORT. THE PROGRAM WILL STILL RUN IN DEMO MODE.
ANYWAY, THANK YOU FOR YOUR OPINION
Check the problem with your local reseller, they should be able to sort it out.
