2023-04-24 10:26 AM - last edited on 2023-05-09 09:25 AM by Barry Kelly
Suddently my view in Archicad does not fit the window anymore. I tried everything, changing setting of my screen, try to get the window fitting but is does nog anymore and it is to high so i cant get the top bar.
I also tried to remove all top toolbars but the window just move up.
also my Navigator is to high.
Solved! Go to Solution.
2023-04-24 10:48 AM
Try re-applying your Work Environment.
That should reset the position of all the windows and palettes.
2023-04-24 10:48 AM
2023-04-24 02:59 PM
Thanks man, so simple, it worked!
