We value your input!
Gap in insulation
Hi!
Attached,I have a wall and a gap in insulation(in plan and 3D) appeared randomly.If I'm moving the wall,the gap disappears.I'm using Archicad 24 and it has happened before in other versions.I'm trying to figure it out why is it happening.
I would be really glad ,if someone could help me.
Thanks!
4 REPLIES 4
vistasp
It could be something with a higher material priority (in an adjoining wall) cutting this out.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
I changed the junction order and the gap disappeared in plan,but it still exists in 3D.
Select the exterior wall along with the interior wall and open the Building Materials. The materials used in these walls will be highlighted. (You can sort the selected materials to the top.) I suspect the insulation or some other material has a higher priority than the stone veneer. You can probably just increase the priority of the stone until the gap disappears.
Richard
AC26 (since AC6.0), Win10
It worked.Thank you very much!
