HELP!!!!! ASAP can not install archicad 12
I have a sony vaio, and i tried to install Archicad 12 on in but when i put the cd in to install the "INSTALL" button does not show up on the window for me to click on it and install it.
4 Replies 4
Erika Epstein
Have you looked on the CD to find the .exe file to start the install?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
ill try that but when i put the cd in it will run the program and the black box will pop up with the graphisoft logo and the picture of the building but there is no INSTALL button to click that is the only thing missing on the screen everthing else is there
Try posting a screenshot that illustrates your problem.
ci-JoshOs
It's just the launcher thing failing. Just kill it and browse the CD contents. There's a folder in there called ArchiCAD 12, and in there, you want to double-click on the Setup.exe file. That'll start the actual ArchiCAD installation.
Josh Osborne - Central Innovation
Mac Mini
