2005-08-22 11:05 AM
2005-08-30 07:25 PM
2005-08-31 12:59 AM
2005-08-31 04:07 AM
2005-09-06 12:39 AM
2005-09-06 01:57 AM
2005-09-06 02:08 AM
HP Printers - Mac OS: Print only HP Drivers (non-Postscript) built into Mac OS X v10.4 (Tiger)In other words HP is saying "Um. . .we're working on it. . .but here's a way to get it to print. . .and No. . .we don't know when we'll have some actual drivers out for it, so in the meantime. . .we'll call these the drivers, and pretend that you're stupid if you call in for tech support and want to have the features of the drivers on other versions of O/S'es"
Mac OS X v10.4 Tiger and HP Drivers
The latest HP printer driver for this device is built into Tiger for print only functionality and does not require a download or reinstallation of any HP software to print.
This document applies to raster (non-Postscript) HP Designjet, Deskjet, Business Inkjet, and LaserJet printers.
In order to best take advantage of the latest HP driver and new Mac OS X v10.4 Tiger features, it is recommended that you delete original HP printer queues from Printer Setup Utility and create a new HP printer queue.
Tiger - HP printer setup instructions:
Upgrade install from Mac OS X v10.1, 10.2, 10.3 - select 'Reset Printing System" option (from the Printer Setup Utility pull down menu) to delete all previous printer queues. The HP printer queue can also be deleted manually from Printer Setup Utility.
From Printer Setup Utility, click on Add, select connection type (e.g. All, Bonjour, USB, Appletalk) and create new HP printer queue. The Printer Setup Utility is found in the Applications/Utilities folder.
Clean install - If there is a clean install of Tiger, follow step 2 to add a new HP printer queue.
NOTE: Please note that Stuffit Expander is no longer included with Tiger, .sit file downloads will require downloading Stuffit at URL http://www.stuffit.com/mac/downloads.html . This link will take you outside the Hewlett-Packard web site. HP does not control and is not responsible for information outside the HP web site.
2005-09-06 07:39 PM
