Having 2 Different Types of ARCHICAD 19 installed
I have a student who works in the office with me, he has a normal commercial version of AC19 installed as well as AC19 Edu version. He ended up renaming the 2 apps to the above mentioned versions, but that caused an error ( see attachment ).
Is there a way that we can differentiate between the 2 icons?
Thank you for the help.
2 Replies 2
Eduardo Rolon
Do not rename the APP, rename the folder and it should be easier to do it at install since then AC's uninstaller will know were to look.
Then read here to change the icon
http://archicad-talk.graphisoft.com/viewtopic.php?t=23403&postdays=0&postorder=asc&highlight=app+ico...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks very much for the info
