Help on using a laser machine in Ahicad
I need help making architectural models using Achicad. I'm using a laser machine to make models. Has anyone use the laser cutter to make a model using Archicad? Now I have to transfer the file to Autocad and then send it to the laser. I think there would be a way to accomplish this right from Archicad.
Thank you,
Eperez
Laser machine? I use a reverse ionization plasmatizer to make my models.
